overlook
Dec 10, 2013Tutor
RN102 and Active Directory domain
Hello, We currently have 2 ReadyNAS PRO buisiness Edition on our Active Directory domain. They work great (531 days uptime for both today). Now we need a third NAS and the RN102 seems to be the go...
overlook
Dec 11, 2013Tutor
xeltros wrote:
I also have to say that some users are experiencing problems with OS6 stability causing transfer crash and device lock up (solved only by waiting for hours or doing a power cycle) when you do heavy write on the device, an update is to be released soon to fix this. I advise to wait for 6.1.5 or 6.2 update before buying. It seems to be a pure software problem related to BTRFS, so I assume this should be fully solved with the update, but until it's fixed I cannot recommend the device for professional use. But since there are rumors of the update coming in by mid-december...
thanks for info Xeltros & StephenB
The goal is simply for us to have an external backup : ReadNAS Pro BE ===> backup using RSYNC to ===> RN102 on the LAN. As soon as the backup is finished the RN102 goes in another physical place than the RedayNAS Pro. We wish to do that once a quarter. The RN102 would be used only for external backup, no user access.
Then is it a good hardware choice ? If yes, as xeltroys said, we will wait for 6.2 release because the stability transfer is critical !! :cry:
thanks,
