asdfsd
Jan 22, 2019Tutor
RN102 doesn't recognize external USB hard drive
Hello I have a ReadyNAS 102 running firmware 6.9.4 hotfix 1. I purchased an external drive bay and put a 3TB HGST drive in it to back up the RN102. The drive and bay are recognized by my PC over both...
- Jan 28, 2019
The
The issue is now resolved. I will put the steps I used below for others who may have the same problem. To recap:
- Plugging a new HGST 3 GB hard drive in a Vantec NexStar 3 enclosure into either the ESATA or front or rear USB ports yielded no recognition of the drive by my RN102. Rebooting the RN102 with the drive attached made no difference.
- Plugging the same drive / enclosure combination into one of my computers yielded recognition and partitioning / formatting ability via either the USB or ESATA ports.
- In the interim I upgraded my RN102 to firmware 6.9.5 (for original firmware version see OP)
- I then installed the original HGST 1 TB SATA II drive into the Vantec NexStar 3 enclosure, which was recognized by my ReadyNAS.
- I then installed the HGST 3 TB SATA III drive into a new Vantec NexStar 6G enclosure which led to the drive being recognized by the Win 8 PC, then the drive finally being recognized by the RN102 ESATA port. Since I always intended to interface the drive via ESATA, I have not tried USB, though I assume that would also work.
Discussion: The Vantec NexStar 3 enclosure is listed on the Vantec site as being SATA I/II compliant, but Amazon lists it as SATA III compliant as well. The drive is of course SATA III (also known as SATA 6Gb/sec). These are of course theoretical speeds. I asssumed since the drive worked in the enclosure on the PC the problem lay with either the ReadyNAS hardware or software. I now suspect but will not go to the trouble of proving that the problem lay with the drive / enclosure interface which for some reason didn't work with the ReadyNAS.
In short, if you're installing a backup drive for your ReadyNAS, you'll avoid problems by ensuring that the enclosure meets the same standards as your drive.
asdfsd
Jan 23, 2019Tutor
The admin page never shows this drive when you connect it. It does show USB thumb drives, but not this one.
Jan 24, 2019Guru - Experienced User
So did you try reformatting as suggested above?
- asdfsdJan 24, 2019Tutor
Yes, the admin page still shows no drive connected.
- StephenBJan 25, 2019Guru - Experienced User
Do you have a different drive you can test with?
- asdfsdJan 28, 2019Tutor
The
