asdfsd
Jan 22, 2019Tutor
RN102 doesn't recognize external USB hard drive
Hello I have a ReadyNAS 102 running firmware 6.9.4 hotfix 1. I purchased an external drive bay and put a 3TB HGST drive in it to back up the RN102. The drive and bay are recognized by my PC over both...
- Jan 28, 2019
The
The issue is now resolved. I will put the steps I used below for others who may have the same problem. To recap:
- Plugging a new HGST 3 GB hard drive in a Vantec NexStar 3 enclosure into either the ESATA or front or rear USB ports yielded no recognition of the drive by my RN102. Rebooting the RN102 with the drive attached made no difference.
- Plugging the same drive / enclosure combination into one of my computers yielded recognition and partitioning / formatting ability via either the USB or ESATA ports.
- In the interim I upgraded my RN102 to firmware 6.9.5 (for original firmware version see OP)
- I then installed the original HGST 1 TB SATA II drive into the Vantec NexStar 3 enclosure, which was recognized by my ReadyNAS.
- I then installed the HGST 3 TB SATA III drive into a new Vantec NexStar 6G enclosure which led to the drive being recognized by the Win 8 PC, then the drive finally being recognized by the RN102 ESATA port. Since I always intended to interface the drive via ESATA, I have not tried USB, though I assume that would also work.
Discussion: The Vantec NexStar 3 enclosure is listed on the Vantec site as being SATA I/II compliant, but Amazon lists it as SATA III compliant as well. The drive is of course SATA III (also known as SATA 6Gb/sec). These are of course theoretical speeds. I asssumed since the drive worked in the enclosure on the PC the problem lay with either the ReadyNAS hardware or software. I now suspect but will not go to the trouble of proving that the problem lay with the drive / enclosure interface which for some reason didn't work with the ReadyNAS.
In short, if you're installing a backup drive for your ReadyNAS, you'll avoid problems by ensuring that the enclosure meets the same standards as your drive.
Jan 25, 2019Guru - Experienced User
Do you have a different drive you can test with?
asdfsd
Jan 28, 2019Tutor
The
- StephenBJan 29, 2019Guru - Experienced User
A SATA III drive is designed to work with SATA I and SATA II controllers. So while it is pretty clear that there is a compatibility issue with the enclosure, it is not about the SATA III spec.
