Steentje
Mar 18, 2019Follower
RN102: System volume root's usage is 85%
Hi,
Today, my ReadyNAS 102 alerted me with this message: "System volume root's usage is 85%. This condition should not occur under normal conditions. Contact technical support." At the same tim...
- Mar 18, 2019
Hi,
I had exactly the same problem. For the solution, which worked on my NAS, please refer to: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-84-This-condition-should-not-occur/m-p/1722230#M178435
jamesnewton1
Mar 19, 2019Aspirant
Hi So, i also had an issue with my readynas no updating the Antivirus.
Long story very short it was a load of Junk files from Plex, i had a 82% Root Usage.
Im a Linux nube so I will keep this easy for the other Nubes. if you want to use Windows then install a program called putty.
You will need to have SSH switched on from your Option list on the ready nas
in Putty then use the server ip for example
192.168.1.10
log in as root not admin
then use the ready nas server password
this opens up a terminal.
As you are logged in as the root
cd /
to show contents
ls -1
If you have the same issue with Crap from Plex then you can see a load of junkchunk-stream0-00149.m4s
display files size in human form
du -h
mass delete of files
for example
chunk-stream0-00150.m4s
chunk-stream0-00151.m4s
rm -rf chunk-stream0*
Caution think before you delete.
Then dis engaged the antivirus, restarted the system then re engaged the Antivirus and all was good. No more root usage warnings
Mar 19, 2019Guru - Experienced User
While this issue can happen with plex, it won't cause the root usage problem on RN100 systems. Those junk files are used when plex is transcoding - and that feature isn't available on the RN100 ReadyNAS.
FWIW, the recent wave of AV causing excessive root usage seems to be limited to the RN102 and RN104 (though possibly the RN2120 is similarly affected). At least I haven't seen posts here from people using other ReadyNAS.
Personally I am thinking that all RN100 owners should immediately disable AntiVirus on their systems, at least for now.
- CHU1970Mar 20, 2019Aspirant
Hi, I have this problem as well, and pretty new to all this and without a clue how to fix it. Netgear want at least £60 to access their support. I'm wondering why I have to pay for what so far seems to be an error caused by their antivirus updates.
Would anyone be able to give me an idiots step by step guide to fix this issue?
- StephenBMar 20, 2019Guru - Experienced User
CHU1970 wrote:Would anyone be able to give me an idiots step by step guide to fix this issue?
Already posted: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-90-RN102/m-p/1723405#M178497
Amazing!! thank you. All sorted. I hate messing with that sort of thing.
