btwixt
May 23, 2022Guide
RN102 unresponsive after initiating FW update from 6.10.6 to 6.10.7
Initiating update from local admin page, everything seemed normal including the blinking power light during the update process. I received a status email that the unit was rebooting, and I watched...
Sandshark
May 25, 2022Sensei
Power-on with the button is pretty much independent of anything else. It has an input for commanded power off and WoL power-on, but it's hard to figure how a fault in those could keep the button from working. It is powered by the +3.3VSB (created internal to the NAS from the external 12V), but so is the Ethernet (to support WoL). The 3.3VSB is on whether the unit is "off" or not.
Given the Ethernet seems to be working (though no address assigned because the processor never negotiates one), that probably eliminates the 3.3VSB as the cause. It may be something else in the power-on circuit that is causing the problem with the power on/off, something that may have happened some time ago but was not detected because the NAS was never powered off.
I think your issue with the button and the NAS not booting may be separate issues. I think you should at least assume that for now.
Given it doesn't even show up in RAIDar with no drives, the next thing I can think of is it's a UBOOT issue. A USB recovery is supposed to fix that, though I've seen instances posted here where it didn't seem to. Still, it shouldn't hurt even if it's not the fix. Given you can get to and go through the boot options, I don't think it's a CPU or RAM issue (not that either is repairable).
btwixt
May 25, 2022Guide
Good analysis.
I have not tried the "secret" 4-pin header serial port.
Is that worth the effort?
The fact that memory test, while it seems to start, does not behave as
described in the documentation would seem to put another nail in the
final diagnosis coffin. Are there enough nails yet to call it a brick?
- SandsharkMay 25, 2022Sensei
But the memory test also relies on UBOOT to at least get started. So I don't think you're ready to call it a brick yet.
- btwixtMay 25, 2022Guide
Sandshark,
If you haven't already, check out my latest post of bizarre behavior here:Re: USB Recovery and boot menu > memory test with reference to OS updates and making brick
- btwixtMay 26, 2022Guide
Sandshark,
I reread your statement and wanted to clarify a point.
Re: "But the memory test also relies on UBOOT to at least get started."
The thing is, I am uncertain that memory test actually started as the rapidly flashing
POWER LED is used as an indication of many different events (unfortunately)
and may not mean memory test has started but that some error/event has occurred
not directly related to memory test.
- StephenBMay 26, 2022Guru - Experienced User
btwixt wrote:
Sandshark,
I think Sandshark is agreeing with you here - he's saying that the memory test relies on UBOOT, and if that isn't functioning, then the memory test might not have started.
- SandsharkMay 26, 2022Sensei
Yes, I am saying that both the memory test and normal booting could be adversely affected by a corrupted UBOOT. A USB recovery is what I believe you should try next.
Re: USB recovery
I have tried about two dozen times.
I've tried with about a dozen different flash drives.
Each try went as follows:
Insert flash drive, hold the BACKUP button, and apply power (unit is stuck in the state where it powers on without touching the power button.)
The POWER and BACKUP LED start flashing rapidly and there are a couple of bursts of activity indicated by the flash drive LED.
I have not yet released the BACKUP button (instructions say to hold it in for a full 30 seconds.)
The flash drive activity ends in about 6 seconds.
The POWER and BACKUP LED have been flashing rapidly since power application, and continue to flash.
30 seconds after power application I release the BACKUP button.
The POWER & BACKUP LEDs continue to flash.
The minimum amount of time until I remove power and try again has been 20 minutes.
(Is that long enough?)
A few attempts left power applied, POWER & BACKUP LEDs flashing madly away the whole time, for over 4 hours.
- btwixtJun 01, 2022GuideFolks, I'm willing to try anything to resurrect this unit.
What are the chances of acquiring the necessary software / hardware documentation, including any debugging fixture details, to fix this thing? - StephenBJun 02, 2022Guru - Experienced User
What are the chances of acquiring the necessary software / hardware documentation, including any debugging fixture details, to fix this thing?There isn't really much that can be repaired. The chips aren't socketed (both memory and the CPU are soldered to the system board).
One easy thing - we never completely ruled out a power issue. You could try connecting a power brick from one of the replacements you purchased, and see if the system boots normally. Best to use a spare disk of course.
- btwixtJun 02, 2022Guide
In reply to StephenB:
Re: There isn't really much that can be repaired.
>With respect, Steven:
>This is, and always has been, a matter of will instead of capability.
>There are many surface-mount-capable repair facilities in the US.
>A local (to me) facility is even FAA and MIL-STD-2110/2111 approved.
>I doubt the Marvel chip is at fault (but even if it were, it is replaceable)
>and that leaves all the relatively easy stuff.
>The REAL obstacle would be getting hardware documentation and>possibly sourcing parts. And that would be a matter of will also.
Question about Marvell ARM chip:
Which one, exact part number please, does this unit use?
I would like to know if it is an SOC device with flash memory.
Re: power issue
>Tested, measured (both inside & out of failed unit), and substituted.
>I actually have four supplies to "play" with. All are 90W to 120W units,
>and very quiet from an electrical noise standpoint.I am waiting for a reply on another post regarding testing the only thing
I haven't tested, the serial port.
If the serial port yields nothing, I am off in search of documentation.FULL DISCLOSURE:
At some point while inspecting the insides of the failed unit I discovered
the battery was at 1.98V. I used a fixture to keep battery voltage applied
to the board while I replaced the battery. Even though the original battery
was in this poor condition during the OS update the RN102 was always on a UPS
and never lost power. - StephenBJun 03, 2022Guru - Experienced User
>This is, and always has been, a matter of will instead of capability.Not convinced that the cost of repair is worth what you'd get. We're talking about a 9 year old entry-level NAS. But if you want to give it a try, of course you can.
Netgear doesn't provide the hardware documentation you are looking for - and I don't work for them, and have no access to internal documentation.
Googling suggests it is an 88F6710. But it's probably best if you look at the system board and confirm this.
- SandsharkJun 03, 2022Sensei
Few users have the equipment to de-solder and solder ball grid array parts. Many of the parts cannot be purchased in small quantities. And just figuring out what part(s) need to replaced is going to be quite a task without a schematic. The board most likely won't hold up to just replacing things until it's fixed.
Even Netgear doesn't repair them.
So, at least for most, it is a matter of capability, not will. If you have the appropriate equipment and skills needed, then go for it and please share whatever you learn with the forum.
- btwixtJun 04, 2022Guide
Thanks for all the input!
Yeah, the time & resources I spend messing with the failed unit are just part of my hobby.
Some people like picture puzzles or crosswords. I like resurrecting broken machines.
Well folks, it's been fun. Guess we'll leave this issue unresolved.
The unit died using the online update, causes unknown.
(Makes me wonder if the manual update would have been successful.)
If I learn more I'll post it, of course.
