allenby's avatar
allenby
RN102 webserver admin access
If I enable the webserver it works fine. But how do I then access the admin webpages, since all access is directed to the website folder
Alan
  • The web server should only re-direct http.  https explicity to /admin should still get you to the admin page.  You can do that diorectly in your browser or via RAIDar.
    • allenby's avatar
      allenby
      But latest Firefox (84.0) under Xubuntu 20.04LTS  refuses to accept the security certificate as follows:
      192.168.1.233 uses an invalid security certificate.
      The certificate is not trusted because it is self-signed.
      So I have to allow an exception, so connection drops back to insecure http. So both https and http act the same. Is there any solution to that?
      • rn_enthusiast's avatar
        rn_enthusiast
        Virtuoso
        That is normal. The NAS uses a self-signed certificate. You can just accept it and thus make it an exception in your browser and you won't be prompted with the security warning anymore. Accepting warning this and proceeding should not make the connection revert to HTTP, it should stay as HTTPS.
        If you ever see a warning like this while browsing the Internet, then don't proceed! You are only proceeding here because you know it is your NAS and you trust the relationship between your PC and the NAS. HTTPS certificate warnings are a way for your browser to warm you of potential man-in-the-middle attacks which can very well be the case if you browse some remote server somewhere (i.e. the Internet), but for your NAS it is perfectly fine to allow the browser to proceed and make the exception.
ProSupport for Business
