gregoland84
Dec 29, 2016Aspirant
RN10200 Cannot login to admin, Unable to reset Password
I am quite desperate and really hope someone will be able to help me. I have all my photos and important files on my NAS for the passt few years and I acannot access it anymore. The problem is that I...
- Dec 30, 2016
OK you need to perform a OS Re-install as shown on Page 19 here
This will reset the user login//password to the default values.
These are:
Login: admin
Password: password
It will also change some of your Internet protocol settings to defaults
DO NOT perform a Factory Default as it will delete all of your data
Wickedflies
Apr 02, 2017Aspirant
Ok that worked!. I got in through that admin sign in.
I did notice that my login (the one I was trying to use to log in) got wiped. So did all authorised users for cloud got wiped. And ready cloud was switched off. ?????? Any reason why this might have happened? Was it a security thing?
- jak0lantashApr 02, 2017Mentor
Try read the other threads, most of the threads under ReadyNAS section in the past two-three days are about this.
