ecybertom
Feb 06, 2017Aspirant
RN104 - "Remove inactive volumes to use the disk." problem #27199519
I was 'running out of room' with 2X6TB disks and 2X5 TB disks, installed 5-6-5-6. I replaced the slot 1 disk with an 8GB disk, giving an 8-6-5-6 arrangement. Resync et al went well. I then added another 8TB in place of the other 5 disk, giving an 8-6-8-6 arrangement. Resync 'seemed' to go well till the unit went into another resync which resulted in both 8TB disks being switched to inactive. When looking at the volumes page, I see two apparently different raid arrangements; a RAID 5 showing the same capacity as I started with and a RAID 1 showing no capacity. Firmware is 6.6.1. I have jpegs of the screens and a download of the logs but can't find how to attach them to this message
You should see a picture insertion icon right next to the hyperlink chain icon in the toolbar (8 over from the "B").
- xiao123NETGEAR Expert
Hi ecybertom,
Could you send log of your problem nas to us for more detail info ?
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
