RatPC
Dec 06, 2019Aspirant
RN104 - Unable to view Shares in GUI - RNOS 6.10.2
Evening All,
A bit of a strange one going on here, and i cant quite work out what is going on.
Logging in to the WebGUI and looking at the shares page it only shows me the home folders as shown in the attachement.
I enabled SSH and logged in and I can see all the shares still there, and I have RW access to them currently as well.
root@NAS:/# btrfs subvolume list -o /data/ ID 256 gen 648872 top level 5 path home ID 257 gen 657609 top level 5 path .apps ID 258 gen 7 top level 5 path .vault ID 259 gen 640345 top level 5 path Pictures ID 260 gen 657579 top level 5 path Videos ID 262 gen 644787 top level 5 path Documents ID 264 gen 657612 top level 5 path ._share ID 265 gen 657612 top level 5 path .timemachine ID 392 gen 657606 top level 5 path Music ID 6448 gen 657612 top level 5 path .purge ID 6617 gen 657524 top level 5 path Nicky ID 8472 gen 640839 top level 5 path NICKY-HP-Pictures ID 10990 gen 648768 top level 5 path Ryan
I even tried creating a test share to see if that worked, which it did and that displayed on the share page too. This has only happened since i installed RNOS 6.10.2, before this i had no issues.
Any advice welcome!
Many thanks
RatPC
Hi RatPC,
Welcome to the Community!
If you are comfortable in using SSH on your NAS, you can try running the script provided here.
That should fix the issue that you are currently experiencing on your NAS.
- RatPCAspirantThat’s worked perfectly!
I will reset the Permissions in the morning :)
