desantj
Apr 20, 2021Aspirant
RN104 - "USB Boot Failed!" on Display, USB Recovery Drive not Working
Hi, my RN104 was successfully updated to FW 6.10.4 when the FW became available. It's functioned fine until now. I normally have it powered off and I know it does power on by itself occasionally (a...
Apr 23, 2021Guru - Experienced User
If you aren't running usbrecovery.exe with elevated privilege, then try doing that.
But it is possible that the internal flash has failed.
