InteXX's avatar
InteXX
Luminary
Jun 29, 2015
RN104 + 6TB
Will the HCL be updated to include WD 6TB Reds for the RN104?
If I use the 6TBs should I count on being denied support in the event of a problem?
Thanks,
Jeff Bowman
Fairbanks, Alaska
  • Probably or probably not, but the RN104 should be able to handle 6TB drives. Yes, there will be no support for drives that are not on the HCL unfortunately.
    Very good, thank you.
    Thanks,
    Jeff Bowman
    Fairbanks, Alaska
ProSupport for Business
