Calder
Feb 27, 2017Guide
RN104 100% CPU within 1 month of restarting
This started 2 updates ago (6.6.0). Within 1 month or a fresh restart, both of my RN104 will suddenly reach 100% usage within a few minutes of each other. This has been happening for a few times no...
HolgerGT86
Feb 28, 2017Guide
I can confirm that disabling the AV service resolved this issue for me and my 104.
Symptoms were timemachine unable to find timemachine backup volume, admin website did not load or reconnected or reloaded all the time, out of disk space messages. All this went away after disabling the AV service.
- Retired_MemberFeb 28, 2017
Great to hear that. Let me recommend to keep it disabled until the new firmware 6.7 will be available. You could also try to toggle it on again and see whether it decides to behave now. At least you have a workaround.
- CalderFeb 28, 2017Guide
Thanks for the tip. Unfortunately I don't use AV or time machine or any "fancy" features. Mine are both just a iSCSI setup with a SMB share for image storage. I have checked that I don't have anything scheduled for the volume like blanace, defrag, etc.
Maybe next update will fix this issue and my other issue with UPS not being detected after a restart.
Cheers!
- CalderMar 24, 2017Guide
Yup, as predicted, it happened again 23 days after last restart. Both RN104 went to 100% CPU and stuck there. I guess I am on a 3 week restart cycle with these two NAS.
- mdgm-ntgrMar 24, 2017NETGEAR Employee Retired
Are you able to send in your logs (see the Sending Logs link in my sig)?
