majtik
Dec 29, 2017Aspirant
RN104 and replacing HHD with brand new one
Hi, I need your help pls. In my RN104 I have 4+2+2+4 TB disks. Now one ( the oldest one 2TB ) died, on admin page appeared status: Degraded ( yellow mark ). Volume type RAID 5. So I bought brand ne...
Dec 29, 2017Guru - Experienced User
Do you have XRAID enabled? (Check for a green stripe on the XRAID button on the volume tab).
If XRAID is enabled, then try rebooting the NAS next.
- majtikDec 29, 2017Aspirant
Yes, I have Xraid enabled and maybe thats why I cant do new Volume on new HDD ?
But in the picture in the menu Volumes I can see only 3 drives a the place of new one is empty, not grey drive, like on this picture:
https://community.netgear.com/t5/New-to-ReadyNAS/ReadyNas104-Adding-a-new-hard-drive/td-p/984673
In manual on Netgear site i found:
and
https://kb.netgear.com/22891/How-do-I-access-the-boot-menu-on-my-ReadyNAS-104-204-214-or-314
I would try do to Factory default with only the new disk ( the 3 old disks take out from NAS ), but I need to know, that if I won´t be sucessfull, I can put back my 3 old drives and the data will still be on them.
- StephenBDec 30, 2017Guru - Experienced User
Don't do that, it won't accomplish anything. If you try to add the three old drives back, you will lose all your data. You'd have to boot with only the old disks installed, and then reinsert the new one. Then reformat it to add it to the array, which undoes the factory default.
The NAS doesn't seem to be detecting the new disk. That suggests the disk might have failed (perhaps during shipment). Can you test it in a Windows PC with WDC's lifeguard program? You can attach it either with SATA or using a USB dock/adapter.
- majtikDec 30, 2017Aspirant
1. How can I do that ? ( step by step pls )
I attached it firstly using USB adapter - Win 10 - In administration of disk, I can see it, but it is not incialized - I tried - but got some error - but this can happen when connected via USB adapter ( as I found in some discussions ) )
I will probably open PC case and connect it directly via SATA cable, but if I make inicialization and format in PC , is it possible to add it to the NAS without Factory default and loosing of my data ?
Or can I use WDC's lifeguard program without inicialization ( or with inicialization but without format ) ?
And last general question: If I have only disk from PC ( formated FAT 32 or NTFS ) and want to use it in NAS ( Xraid) to replace one of disks, it is impossible to preserve my data on NAS ???
