Kardano1
Jun 20, 2015Guide
RN104 defrag problem
RN104, FW 6.2.4 4x3TB WD RED , RAID5 , x - raid , AV Off, Snapshots ON running apps : SMBplus , Transmission, Linux-Dash, PHPSysinfo, Cacti, BTsync 1.4, istat, PHP, instaled apps but turn Off: V...
Jun 20, 2015Guru - Experienced User
I believe the log will only show the scheduled maintenance. It sounds like the defrag is still running (at least the NAS software thinks that's the case).
How much free space is in the volume? Did you try deleting snapshots before doing the defrag?
Also, have you ever tried balance?
BTW, snapshots should certainly be off in the transmission data folder, and possibly also btsync.
