petercae
May 14, 2019Guide
RN104 Don't update to 6.10.0 Firmware!!!
Update at your own risk.
After Netgear in their wisdom released this buggy and obviously untested firmware version for the rn104, I mistakenly clicked on the update button.
The new firmware kille...
petercae
May 18, 2019Guide
Finally after over 90 hours the resync is finished!
SMB Plus is failing to install.
Are you guys having the same problems installing some apps?
I have a new 6TB HDD for backup will the R104 see the NTFS partition?
Retired_Member
May 18, 2019Hi petercae, you wrote "SMB Plus is failing to install." and I can confirm, that the app is not running on my RN104 with the same OS level, too. I have opened a new topic for this and you might want to follow the link below to go there.
Kind regards
