DeePin
Apr 04, 2018Aspirant
RN104 Lost data after reboot
Hi, New to asking for help in this way. 4 Bay Raid 5 I have a RN104 which had 2 of the bays unclipped whilst on, accidently, it was then powered down and put back together. when restarted the driv...
- Apr 04, 2018
or has the data disappeared through the processes I have taken already.If you destroyed the volume (in your Removed Volume step), then you destroyed the data in that volume. You would have been prompted to type "DESTROY" as part of that process.
Apr 04, 2018Guru - Experienced User
- DeePinApr 04, 2018Aspirant
Thanks I jump the gun with my actions really, can only be described as panic.
will the data still be in tact for recovery? if I reintialised the drives through another hardware setup.
Also what should I have done?
Thanks for you time
- StephenBApr 04, 2018Guru - Experienced User
It's conceivable, but not very likely. It'd be expensive to get it back. You could try powering down, connecting the disks to a Windows PC, and then see what ReclaiMe can recover. You'd have to pay for the software if you want to actually do the recovery though.
The longer you let the NAS run, the less likely it is that recovery would be possible.
DeePin wrote: Also what should I have done?
The best way to deal with the inactive volume issue is to contact (paid) support at my.netgear.com.
This of course isn't needed if your backup is up to date.
Thanks StephenB
Will give it a go.
- DeePinApr 06, 2018Aspirant
FYI Just ran a scan and have found all the data will extract and update backup strategy.
Thanks for all you help
