DeePin
Apr 04, 2018Aspirant
RN104 Lost data after reboot
Hi, New to asking for help in this way. 4 Bay Raid 5 I have a RN104 which had 2 of the bays unclipped whilst on, accidently, it was then powered down and put back together. when restarted the driv...
- Apr 04, 2018
or has the data disappeared through the processes I have taken already.If you destroyed the volume (in your Removed Volume step), then you destroyed the data in that volume. You would have been prompted to type "DESTROY" as part of that process.
Apr 04, 2018Guru - Experienced User
DeePin
Thanks I jump the gun with my actions really, can only be described as panic.
will the data still be in tact for recovery? if I reintialised the drives through another hardware setup.
