Lesage's avatar
Lesage
RN104 OS695 unable to send alert messages
Hello,
Since May, 2018, my RN104 is unable to send alert messages.
Formerly, this was working well.
When using the "Send message" test, I get a pop-up window which says : "Unable to send message, check parameters".
I do not use Microsoft,  nor Google message systems. I use a mail account from my internet provider (Orange, France).
I have tried several times to suppress, then re-enter the message parameters. I have checked these parameter's validity with Oultlook to make sure there was no error. I have closed down, then re-started the RN104 unsuccesfully.
I am used to update the OS6 software as soon as I notice a new version, Presently it runs under OS695HFix1. The problem still exists
Best regards
  • schumaku's avatar
    schumaku
    Some insights - access your ReadyNAS by ssh and the root account (has to be enabled) using the admin password.
    The SMTP config is held (this hasn't changed for a while when I have it right) in /etc/msmtprc
    # cat /etc/msmtprc
    ... (don't post to much - coan contain real email and password details)
    The email notification systems does log to  /var/log/frontview/msmtp.log so (successful only?) messages are logged here
    # cat /var/log/frontview/msmtp.log
    Most easy one ot start investigating is using
    # sendmail -i [emailaddress]
    test
    (emtpy line!)
    (empty line!)
    CRTL-D
    (emtpy line!)
    (empty line!)
    (empty line!)
    root@RN628X:~# sendmail -i towhateeremailaddress@wherever.test
    sendmail: envelope from address email-for-authentication@domain.demo not accepted by the server
    sendmail: server message: 535-5.7.8 Username and Password not accepted. Learn more at
    sendmail: server message: 535 5.7.8 https://support.google.com/mail/?p=BadCredentials q19sm2009370eja.59 - gsmtp
    sendmail: could not send mail (account default from /etc/msmtprc)
    Ok, I've used a "real" email hosted at Google, and they are informative - for this demo I had chaged the config file manually.
    The required configuration for orange.fr is here (when I have it right):
    Outgoing Mail Server
    Account Type: SMTP
    Username: Your email address is your username
    Server hostname: smtp.orange.fr
    Server port: 465
    Authentication: Password
    SSL/TLS: Yes
    • Lesage's avatar
      Lesage
      Thank you for the response
      I understand that you suggest to connect to the ReadyNas through an SSL connection from another (distant) computer, then inspect the log file, which is hidden in the root account. Of course, access to this root holder/file should be enabled beforehand.
      Do you mean that the log file is unaccessible from Windows Explorer upon my Windows10 PC ?
      I have checked the configuration for the outgoing mail server : it is correct
      Best regards
      • schumaku's avatar
        schumaku
        Sure ... SSH it is, yes and yes.
        However it does not work ...
ProSupport for Business
