dcourt
Nov 07, 2022Aspirant
RN104 stuck in Boot Menu
Hi I tool at look at my RN104 this morning as I couldnt access a file from it... I havent done any FW upgrades or anything, and it was working normally yesterday.. Today - Looking at the NAS: ...
Sandshark
Nov 07, 2022Sensei
Your UBOOT is probably corrupt and a USB recovery should fix it unless the memory itself (not just the content) is bad.
- dcourtNov 07, 2022Aspirant
I have tried a USB recovery. I ve created a USB stick, and booted the NAS from the stick. It completes, then powers off - but when I power on the NAS again - same symptoms đ
is there any way I can get to the memory to reseat it, or is it hard wired to a board?
- StephenBNov 07, 2022Guru - Experienced User
Memory (flash and ram) are soldered to the board.
Have you tried powering down, removing the disks (labeling by slot), and then powering up? See if the NAS reports a "no disks" status.
Normally the NAS will boot from disk 1, and there are situations where an issue with disk 1 will result in a failure to boot.
