GDM52
Aug 06, 2019Aspirant
RN104 Upgrade to 6.10.1 breaks Apache2
Hi, I have just upgraded firmware from 6.9.5 to 6.10.1 but apache2 is not starting properly, so am unable to access my web server. Frontview (Admin Console)is working OK. Aug 06 17:00:42 read...
Marc_V
Aug 06, 2019NETGEAR Employee Retired
GDM52
Sorry - Don't use RAIDar
Any alternatives???
- GDM52Aug 06, 2019Aspirant
I have a zip file of the logs ... what shall i do with it?
- Marc_VAug 06, 2019NETGEAR Employee Retired
Can you update or reinstall the phpmyadmin and pho apps. This needs to be updated too to get the latest package compatible for 6.10.1
Unistalled both, rebooted.
Can't reinstall them ... I suspect because they test if apache2 is running (which it's not)
Cheers
