saf1's avatar
saf1
RN104 WD Red 6TB Drive
Hi Everyone.   I've been slowly replacing my hard drives with the Western Digital 6 TB drives in my Ready NAS 104 storage system with the last one being added over the weekend.  This morning when t...
  • saf1's avatar
    saf1
    Mar 09, 2016
    Ok, the resync finished.  What a huge difference and more inline with what I was expecting.  I now have 8 TB free out of a 16.3 TB.  Not too bad.  May have not been the best choice of $ per TB but all in all I can't complain.  I bought the drives over time.  Thanks again for taking a look at the problem.  It appears to be resolved.
    With regards to upgrading, I'll be adding it to my budget and plan.  I still have a bit of homework to do but it would be great if I could just buy a new chassis like you noted, RN214, shutdown my existing unit, remove drives, insert into the new RN214, and pick up where I left off.  That would be pretty slick.  The only thing I didn't like about the 214 is that I was concerned about the ARM processor.
    It looks like the Rn214 is the top end right now for typical home use whereas the rest are for business.  Either way, I'm still sold on the unit and I can't thank you enough.  Super nice.
    THANKS!
    -scott
ProSupport for Business
