Garthadam's avatar
Garthadam
RN104 Drive not available
New system. Only been running for 2 days. I have 2 * 4tb WD red drives. Both drives show in the admin page when i look at volumes and performance however I am only showing 3.61TB of free space. I tried a hot remove and insert on drive 2  but nothing changed. I did recieve a warning that 'volume data has changed from redundant to degraded' upon removing the drive.
  • The RAID redundancy gives you some protection for your data when a disk fails.  Normally all you need to do is replace a disk when it fails.  Your data remains fully available during the entire process.  Also, when you add a disk the volume automatically expands - again your data is still available throughout the process.
    For most users this is a desired feature (and it is the default).
    If you decide you don't want it, you can convert to jbod, which will give you two 4 TB volumes with no redundancy.
    Either way, you should have a backup plan in place.  Devices can fail, so it is unwise to trust your data to a single device.  If you do, at some point you will lose it - its just a matter of when.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    That is a normal amount of free space.
    The default config of X-RAID is in use so if a disk fails your data remains intact. Backups are still important. Did you want a different volume configuration?
    • Garthadam's avatar
      Garthadam
      But if i have 8TB installed why does it show that only half is available? I would prefer staying with default configuration.
        mdgm-ntgr
        Your data volume is redundant. The data is on both disks. Have a read about RAID-1.
        If you add a third disk your volume capacity will double. Have a read about RAID-5.
ProSupport for Business
