saf1
Mar 07, 2016Aspirant
RN104 WD Red 6TB Drive
Hi Everyone. I've been slowly replacing my hard drives with the Western Digital 6 TB drives in my Ready NAS 104 storage system with the last one being added over the weekend. This morning when t...
- Mar 09, 2016
Ok, the resync finished. What a huge difference and more inline with what I was expecting. I now have 8 TB free out of a 16.3 TB. Not too bad. May have not been the best choice of $ per TB but all in all I can't complain. I bought the drives over time. Thanks again for taking a look at the problem. It appears to be resolved.
With regards to upgrading, I'll be adding it to my budget and plan. I still have a bit of homework to do but it would be great if I could just buy a new chassis like you noted, RN214, shutdown my existing unit, remove drives, insert into the new RN214, and pick up where I left off. That would be pretty slick. The only thing I didn't like about the 214 is that I was concerned about the ARM processor.
It looks like the Rn214 is the top end right now for typical home use whereas the rest are for business. Either way, I'm still sold on the unit and I can't thank you enough. Super nice.
THANKS!
-scott
Mar 07, 2016Guru - Experienced User
If you have 4x6TB installed, the volume size should be 18 TB (~16.3 TiB). There is no expansion limit with OS6.
saf1
That is what I also thought, and was sort of expecting. However, after all is done it is showing 4.3 TB free of 12.7 TB.
Ok, I'll have to dig around then. Only thing I can think of is that it is reporting all is done rebuilding and syncing but it really isn't.
- mdgm-ntgrMar 07, 2016NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
