Oz0ne
Jun 09, 2017Tutor
RN10400-100NAS won't power up, but power supply has green light
Hi all,
My RN10400 recently stopped powering up. The power supply shows a green light, but the unit doesn't have any power. I don't know if I just need to replace the power supply or if there was a different hardware failure. Is there anyway to rest the unit? Anyone have any suggestions before I buy a replacement power supply. If I need to replace the power supply can someone confirm P/N 332-10581-01 is what I need. I found this on amazon as a replacement power supply. https://www.amazon.com/UpBright-Adapter-CAM090121-332-10581-01-3321058101/dp/B01M16J45U/ref=sr_1_1?ie=UTF8&qid=1497032584&sr=8-1&keywords=332-10581-01
Thanks for any help
- Anonymous
In case it is connected to an UPS you might want to try connecting it directly to the wall instead.
- Oz0neTutor
Great question. It is not connected to a UPS it is dirrectly connected to a wall socket.
Retired_Member wrote:In case it is connected to an UPS you might want to try connecting it directly to the wall instead.
- Anonymous
Well, being paranoid, I would also try a different wall socket, if you have one in reach.
