RudolfJan's avatar
RudolfJan
RN202 connection does not accept username/password
Hi, I just started using a new RN202. Setup works fine, Updated to the latest firmware version. I created a folder and want to connect using a drive letter form my Windows 10 desktop.
The first step works fine, it accepts the share name: //Nas2/media/Gebruikers
For the share I switched on SMB and anonymous access
The Windows asks for a "reference"  user and password
I tried to:
a) ignore it
b) use the admin username and password
c) create a user,and enter that username/password
tried my windows username (not password protected)
Nothing seems to work. How do I get access? It is nowhere described in a simple way in the software manual.
I want anonymous access without password.
So, not very happy at the moment. This takes far too much time.
Hope someone can help me out.
Thanks in advance.
Rudolf
  • For some reason it is working now. No idea what went wrong.
  • StephenB's avatar
    You have the slashes backwards - \\Nas2\media\Gebruikers
    It shouldn't need a user account (unless the PC user logon happens to match a user acount on the NAS).
    Try running cmd in windows and type
    net use * /delete
    net use t: \\Nas2\media
    That ought to map the media share to the "t" drive letter.
    • RudolfJan's avatar
      RudolfJan
      Thanks for answering so fast. Unfortunately this does not solve the problem. I would like to include some screenshots, but it the image options have been grayed, so I will try giving as much detail as possible on what I see:
      In the shares tab, I have three shares:
      Home folders. Protocols SMB, DLNA, permissions admin (I cannot change the permisions here)
      Gebruikers, protocols SMB, permissions anonymous
      Backup, protocols SMB, permissions anonymous
      Properties for "Gebruikers" Network access tab (SMB):
      Security All
      User group everyone: Read/write
      User group users: no access set (I only can set it to read)
      User admin: access read/write
      Hosts: nothing set
      DFS: nothing set
      Advanced: nothing set
      Using the commands as you instructed cause following effect:
      net use * /delete:
       says nothing in use
      requests a user name and password, but does not accept the admin user/password
      So what am I missing?
        RudolfJan
ProSupport for Business
