dweinshel
Sep 01, 2020Tutor
RN2022 USB drive disconnecting
Last week or so almost daily disconnection and reconnection of USB drive. No other errors Just get the email'ed notification. What does this mean? Thanks DW
dweinshel
Sep 02, 2020Tutor
I have 2 USB drives attached to the 2 USB 3.0 ports on the back of the unit.
The messages actually are 2 USB drive connected messages in the log.
This is new.
I would only get messgaes like that if I rebooted the NAS.
Thanks
DW
Sep 02, 2020Guru - Experienced User
Are you seeing on both drives at the same time?
You might want to check the cabling (both the USB cables, and any power cables to the drives).
