Kardano
Nov 18, 2016Luminary
RN204 - volume lost?
I need help. My RN204 refused all writes. After reboot no data volume. NAS writes: REMOVE INACTIVE VOLUMES to use disk. Dosk #1,2,3,4. I downloaded logs, i see admin page. Tried reboot a...
Nov 18, 2016Guru - Experienced User
You should arrange for paid Netgear support via my.netgear.com. Ask about per-incident support.
Kardano
I try boot to readonly mode.
I diag log from Raidar is this:
- 2016-11-19 07:02:36: ufsd: "mount" (sde1): is mounted as NTFS at 2016-11-19 06:02:36
- 2016-11-19 07:02:16: BTRFS critical (device md127): unable to find logical 46033469440 len 4096
- 2016-11-19 06:59:32: ufsd: "umount" (sde1): is unmounted at 2016-11-19 05:59:32
- 2016-11-19 06:32:46: ufsd: "mount" (sde1): is mounted as NTFS at 2016-11-19 05:32:46
- 2016-11-19 06:32:25: BTRFS critical (device md127): unable to find logical 46033469440 len 4096
- 2016-11-19 06:31:27: ufsd: "umount" (sde1): is unmounted at 2016-11-19 05:31:27
- 2016-11-19 06:28:52: ufsd: "mount" (sde1): is mounted as NTFS at 2016-11-19 05:28:52
- 2016-11-19 06:28:32: BTRFS critical (device md127): unable to find logical 46033477632 len 4096
- 2016-11-19 06:28:31: BTRFS critical (device md127): unable to find logical 46033469440 len 4096
- 2016-11-19 06:27:50: ufsd: "umount" (sde1): is unmounted at 2016-11-19 05:27:49
- 2016-11-19 04:02:01: BTRFS: error (device md127) in btrfs_commit_transaction:2083: errno=-5 IO failure (Error while writing out transaction)
- 2016-11-17 12:39:53: ufsd: "mount" (sde1): is mounted as NTFS at 2016-11-17 11:39:53
- 2016-11-17 10:21:11: ufsd: "umount" (sde1): is unmounted at 2016-11-17 09:21:11
- KardanoNov 18, 2016Luminary
a asked negear support for per incident support case no 27686423.
is there any way to mount forcefully data partition so i can copy some data?
- FramerVNov 19, 2016NETGEAR Employee Retired
Hi Kardano,
We do not know how severe the issue is so I am unsure also if what you are requesting can be done. Let us wait for the support to respond to you, they might be able to tell if what you want is possible or not at this point.
- BiteitNov 20, 2016Aspirant
Hi... A have same problem 2016-11-19 So now a must contact support on monday so support fix this.. A have google this problem and a find many have same problem on 2016-11/ Day 18-19 So it must by system problem But a have "4 disk" is not online and a can not get 4 online "is red"... Is says only remove inaktive disk.. A whas on my company work when this happend and hole life is in this nas
