Kardano
Nov 18, 2016Luminary
RN204 - volume lost?
I need help. My RN204 refused all writes. After reboot no data volume. NAS writes: REMOVE INACTIVE VOLUMES to use disk. Dosk #1,2,3,4. I downloaded logs, i see admin page. Tried reboot a...
Biteit
Nov 21, 2016Aspirant
Hi..
A have talk to support now and level 2 support will take a look on this now in 24 hour and call me/ mail me.. All this happend after a enable Amazon drive backup so now a must wait for support call me...
A hate to wait :( for this is system problem and not my fault for a was not home
dmacleo
Nov 21, 2016Guide
just odd how out of the blue mine died when watching a video from it.
plenty of free spce, on ups, no issues with it on firmware 6.5.x and suddenly 6.6.0 upgrade then this on same date others had same issue.
odd.
wish could roll back to 6.5.x on it.
- KardanoNov 21, 2016Luminary
My RN204 has problem abou 04:00 morning. I was sleeping, NAS was doing maintenance (balancing).
Then all goes to hell.
No answer from support until now. Still waiting. I don't know how much is support per incident....
If you some day cannot write to your nas, it may be...that data volume is on read only mode. DO NOT RESTART UNIT. BACKUP all you need FIRST! THAN restart unit.
I restarted it first and that was my BIG mistake! (and there was some data that has broken backup as i found later).
- BiteitNov 21, 2016Aspirant
Last time I noticed that some folders I could not save to and checked Rights but everything looked good and nothing in the logs ... Nas has worked great until I turn Amazon Cloud backup A want to make sure that a have good backup too of everything and now I get into many errors report rings from several webpage
I watch the same thing on OS 6.6.0
A restart NAS and same problem But a have no volymes in my NAS before a restart NAS This was inactive
No contact from Netgear support. No word, no e-mail.
Case no. is 27686423.
Is it possible to check if there is some progress please? (someone form Netgear...)
I need my unit running.
Thank you very much.
