jbnavy94
Aug 01, 2020Aspirant
RN212 not connecting to Internet for anti-virus update
I just moved the location of my RN212 to a new house / new network. Setup fine. Backing up all data on PC's within network fine. I can't get it to connect to the Internet to do an Anti-Virus update. ...
jbnavy94
Aug 02, 2020Aspirant
Thanks for the suggestion on the clock. It is connecting...just pulled this from the connman.log...it has consistently updated since I connected to this network. jb
Aug 02 11:51:38 nas-Austin connmand[1911]: ntp: adjust (slew): -0.186878 sec
Aug 02 12:08:43 nas-Austin connmand[1911]: ntp: adjust (slew): -0.056553 sec
Aug 02 12:17:39 nas-Austin connmand[1911]: ntp: adjust (slew): +0.010190 sec
Aug 02 12:34:45 nas-Austin connmand[1911]: ntp: adjust (slew): +0.378319 sec
Aug 02, 2020Guru - Experienced User
Then it's likely the issue others have reported. FWIW, I'm not seeing this problem.
If you are comfortable using ssh, you can update the definitions manually. You'd log in as root, and use the NAS admin password. Then just enter this:
# freshclam
