jkucukov's avatar
jkucukov
RN2120 Full Disc Inactive Volumes
HI, Its been a while since I have gone and purged my 24/7 video recordings, as I went to check on my files I couldn't access the folders on the NAS anymore, I can still log in and navigate through the OS through the IP address but all drives are shown as inactive. From the Kernel.log file this is whats shown:
Feb 21 18:35:07 nas-36-12-CE kernel: BTRFS critical (device md127): unable to find logical 13915984560128 len 4096
I had no idea that the discs become inaccessible when full, is there a way to access the drives to make space for further operation?
Thanks,
  • StephenB's avatar
    They don't always, but running out of free space can result in the file system becoming corrupted.
    It's not the only cause though - are you sure that the issue was a result of a full volume?
    If you have a backup (or don't need the data), then the simplest path is to destroy the volume and re-create it.
    If you need to offload data, you will probably need data recovery.
    • jkucukov's avatar
      jkucukov
      The performance status of all 4 discs appears healthy. Is it possible to go into read only mode to take out the important files first?
      • Sandshark's avatar
        Sandshark
        Sensei
        By definition, you cannot delete anything when in read-only mode.  Have you even been able to boot to read-only mode?
ProSupport for Business
