infotek
Oct 28, 2016Follower
RN2120: what is the actual maximum raw disk size?
Literature reports conflicting maximum raw disk size. 32TB http://www.downloads.netgear.com/files/GDC/datasheet/en/RN2120v2-RN3138.pdf 24TB http://www.downloads.netgear.com/files/GDC/data...
Oct 28, 2016Guru - Experienced User
32 TB.
Though RAID sync times will get longer as the disks get bigger. The RN2120 is the slowest business NAS, it's sync times are already the longest. So you might not want to max the capacity.
