DaveOKC's avatar
DaveOKC
RN21200 setup volumes
I setup my RN21200, with two 4TB  drives, using ReadyCloud.   I have a few questions:
1.  From the instructions it appears that I need to set up one or more Volumes in order to set up shared folders.  However, when I view "Shares" from the Admin page it appears that several folders are already set up.  Do I need to do anything else at this point?
2.  When I view "System" from the Admin page it shows a picture of the RN212 with the two SATA 4 TB drives, both colored blue.  Underneath that it has a blue box with "RAID (RAID 1)" by it.  The button on the right side of the page that says "X-RAID" is grey.  When I click on it I am asked if I want to switch from Flex-raid to X-Raid.  Which should I select?  I just want the second drive to backup the first drive.
3.  On the same page I am unable to select "New Volume."  How would I encrypt the drives if I can't create a volume?  Considering that the Admin password can be reset by pressing a button on the back of the unit, why would I want to encrypt the drives.
Sorry if these questions are a little rudimentary, but I'm totally new to NAS, and the instructions are a little vague.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello DaveOKC,
    I have some questions to ask, please see them below:
    • Does the volume of ReadyNAS already have files? Do you have backup of the files?
    • Is this your initial setup for the ReadyNAS? If so, are the disks you inserted used on other NAS that they already have files stored?
    • Does RAIDar detect the NAS? If so, what is the current RAID level and firmware version?
    Please also post a screen capture of what you get from admin page > Volume.
    Welcome to the community!
  • 1. You can either use the default shares or delete them and create the ones you want.
    2. Do you want the second drive to be a second volume so you can backup data from the first volume, or a mirror (RAID redundancy)?
    3. You're enable to select "new volume" because you don't have any unused disk. Encryption is selectable when creating a volume. Resetting the admin password doesn't reset the encryption key, without the USB stick containing the encryption key, the volume can't be read at boot.
    You can find more information about all this in the user manual:
    http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
    • DaveOKC's avatar
      DaveOKC
      Sorry it took so long to get back with everybody but my admin login wouldn't work, even after resetting my password.  I did a OS reinstall and that didn't work  I finally did a factory default and was then able to get to my admin page.  Here are screen shots of what I have now.
      i would like to set this up so the second drive is a backup of the first so that if one drive fails I won't lose my data.
      I would also like to encrypt both drives--so how do I create a volume so that I can do that?
      Thanks, in advance, for your help on this.
      • JennC's avatar
        JennC
        Hello DaveOKC,
        XRAID will automatically give mirror RAID, But since you would like volume encryption, you will have to switch to FlexRAID.
        Click the 2 disks to select them and then click XRAID button, this will allow you to switch to FlexRAID and create a new volume. Select RAID 1, this is the mirror RAID.
        Configure the following settings:
        • Name. Enter a name for the volume. The volume must not have the same name as a folder in the root folder system. The volume names homeapps, and job_ are reserved and cannot be used.
        • Encryption. Select this check box to enable encryption on the volume. A key will be generated. If you lose your key, the data on the volume will be irrecoverable.
        • USB to store key. If you enabled encryption, select a USB storage device from the drop-down list to store the generated key.
        • Send key by Email. If you enabled encryption, select this check box to have the generated key sent to a email address associated with the admin account.
ProSupport for Business
