RichWilson
Apr 24, 2018Tutor
RN214 Drive issue -- Can I move them into 6 bay system
I have two RN214 with 4 drives in each system, set for Raid 5
In one system, the drives have filled up, and the disks are not seen. With error saying a new drive needs added.
Since the d...
RichWilson
Apr 26, 2018Tutor
Ok.. I made the purchase of the 426, and two additonal 6TB drives (the other 4 where 6TB drives).
Put all the drives in with the two newer ones in the bay 5 and 6. I belive the others are 1-4 in order.
I was able to do the firmware upgrade via Raidar, but I can't connect to the admin page. See the attached for what I see.
It appears the drives are properly seated and recognized, but not added to the pool?
Apr 27, 2018Guru - Experienced User
You were able to access the web ui before you moved the drives?
- RichWilsonApr 27, 2018Tutor
To be honest, I'm not sure. I put the drives in before I powered it on.
I've got a support ticket opened. It appears they will need to do the upgrade, because of the Arm to Intel change.
Thanks!
- mdgm-ntgrApr 27, 2018NETGEAR Employee Retired
Downgrades from 6.9.x to pre-6.9.x firmware are not supported:
[2018/04/27 04:52:34 UTC] Root OS arch (arm) does not match flash (x86_64). [2018/04/27 04:52:34 UTC] OS version mismatch [os: 6.9.3(1) / flash: 6.7.1(1493061041)] [2018/04/27 04:52:34 UTC] Migrate from ARM box. [2018/04/27 04:52:48 UTC] Updated from ReadyNASOS 6.9.3 (ReadyNASOS) to 6.7.1 (ReadyNASOS). [2018/04/26 21:10:56 UTC] Updated from ReadyNASOS 6.7.1 (ReadyNASOS) to 6.9.3 (ReadyNASOS).
Is your data backed up?
This looks like a data recovery situation:
[27021.004976] BTRFS error (device md127): bad tree block start 15675119592344921376 20397372899328 [27021.005237] BTRFS error (device md127): bad tree block start 13247143652323685472 20397372899328 [27021.005247] BTRFS warning (device md127): failed to read tree root [27021.005511] BTRFS error (device md127): bad tree block start 6405015776776349577 20397370966016 [27021.005774] BTRFS error (device md127): bad tree block start 17625023173569810370 20397370966016 [27021.005784] BTRFS warning (device md127): failed to read tree root [27021.006021] BTRFS error (device md127): bad tree block start 11209951803827852680 20397367918592 [27021.006248] BTRFS error (device md127): bad tree block start 8544901722416997126 20397367918592 [27021.006252] BTRFS warning (device md127): failed to read tree root [27021.024872] BTRFS error (device md127): open_ctree failed
Data recovery attempts (support would explain what the costs involved are and that the attempt may ultimate prove completely unsuccessful) are best done with disks in a x86 ReadyNAS such as your RN426 as those are more powerful so I would leave your disks in the RN426.
So if you don't have a backup you might need to get some disks for the RN214 and provide that storage as a backup destination for a data recovery attempt.
As you've got 4x6TB disks that are very full, it'd be best to put 4x8TB (or larger capacity) disks in the RN214 as 6TB disks in RAID-5 wouldn't provide enough storage. It's best to keep volumes less than 85% full.
