Astra03
Jul 24, 2020Apprentice
RN214 Failing to Update Antivirus
Hi, For the past week I have been getting a daily alert "System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I have found a number of o...
Astra03
To add to this, the md0 partition says - Size: 3.7G, Used: 1.7G, Avail: 1.8G, Used: 49%.
I also have a stable home broadband internet connection, and in all other respects the ReadyNAS seems to be working flawlessly.
Paul
- StephenBJul 24, 2020Guru - Experienced User
There a couple other folks seeing issues with AV updates.
This is higher than usual. What apps are you running?
- Astra03Jul 24, 2020Apprentice
Hi,
Thanks for reply. Apps currently running:
DVBLink TV Server
Kernel Plus
linux-dash
Logitech Media Server
Transmission for ReadyNAS
So far as I am aware, there have been no recent changes, (updates etc), that co-incide with the start of this problem for me.
Paul
- StephenBJul 25, 2020Guru - Experienced User
Other posters have said this too. One has been able to update using ssh - so that is one option if you are comfortable with linux. I don't use the AV service on the NAS myself, but I did see something similar a couple years ago. I think the issue back then was on the ClamAV end (one of their update servers wasn't working right).
Astra03 wrote:
DVBLink TV Server
Kernel Plus
linux-dash
~50% utilization of the OS partition isn't enough to cause your problem, but it is higher than normal. The OS partition of my own RN202 is about 16% full at the moment. Plex is the only app installed. I don't use AntiVirus (if I did, my OS partition would be somewhat more full, but not 50%).
If the OS partition gets completely full, the NAS will misbehave in a variety of ways (including corruption of the NAS configuration files). 50% isn't dangerously full, but still worth paying attention to.
Likely one of your apps (not Kernel Plus) is using the space. The simplest way to bring it back down is to move some of the folders to the data volume (generally into the hidden .apps folder), and replace the original folders with a symbolic link to the new location. This requires ssh (and some knowledge of linux).
Maybe also check if you are running Transmission or Transmission NT. If you are using the older Transmission, you might want consider switching to Transmission NT and see if that reduces the OS space.
If you don't have the linux skills to troubleshoot (and move folders around), then I suggest periodically downloading the log zip file, and making sure that the OS partition fullness doesn't increase over time. Not sure if linux-dash will give you this info or not (as that also isn't an app I use).
