Astra03
Jul 24, 2020Apprentice
RN214 Failing to Update Antivirus
Hi, For the past week I have been getting a daily alert "System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I have found a number of o...
Jul 24, 2020Guru - Experienced User
There a couple other folks seeing issues with AV updates.
Astra03 wrote:
To add to this, the md0 partition says - Size: 3.7G, Used: 1.7G, Avail: 1.8G, Used: 49%.
This is higher than usual. What apps are you running?
Astra03
Hi,
Thanks for reply. Apps currently running:
DVBLink TV Server
Kernel Plus
linux-dash
Logitech Media Server
Transmission for ReadyNAS
So far as I am aware, there have been no recent changes, (updates etc), that co-incide with the start of this problem for me.
Paul
