Astra03
Jul 24, 2020Apprentice
RN214 Failing to Update Antivirus
Hi, For the past week I have been getting a daily alert "System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I have found a number of o...
AdriFrijters
Sep 18, 2020Tutor
Dear all,
not only antivirus is failing to update. Also the cloud access sets itself form 'on' to 'off'.
I should say; Time for an update of the OS?
A3.
