berillio
Apr 17, 2020Aspirant
RN214 fails to install disk in Bay3
To resolve the problem discussed in https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN-104-failed-to-start-with-quot-Boot-from-USB-quot-no-FW- update/td-p/1878838/highlight/false ...
berillio
sorry, the first link seemed wrong
Apr 17, 2020Guru - Experienced User
I'd run a full erase test on HD3 with lifeguard. If that passes, then hot-insert it into bay 3 again.
- berillioApr 17, 2020Aspirant
ok, I'll that asap. Bear in mind that it was a brand new one, just like the other....
- StephenBApr 17, 2020Guru - Experienced User
Another approach is to do a factory reset with HD3 in slot 1, and then try adding the other disks one at a time.
Sorry I did notmean to solve, I wanted to reply !!!
