BenPatt511
Jun 18, 2020Aspirant
RN214 link aggregation to computer with 2.5Gbe
Hi Hopefully someone can help,
I have the readynas 214 with an SSD cache drive.
I want to get the best out of it, and so set up link bonding.
My router is an Asus ax11000 and supports link bonding and has a 2.5gbe port
My computer also has a 2.5gbe port
They are both wired to the router. However in LACP mode both read and write cap out at 113MBs. In Round-Robin mode I get 205MBs read but still only 113MBs writes.
And I doing something wrong?
Is there a way I can get the same write speeds and I do read spreads in Round-Robin.
Thanks for any help!
LACP is intentionally designed to work that way. Each flow through the bonded connection is capped at 1 gbps. It is also designed to deliver the packets of each flow in order. Technically that is done by having the sender map each flow to a specific NIC
using a hash. You can change the hash, but the fundamental design constraints remain the same.
LACP's main use case is to aggregate ("trunk") traffic between switches, and the design makes a lot of sense for that use.
That's because the NAS is doing round-robin in its transmissions, but your router is doing something else in the other direction. The solution is to reconfigure the Asus to also do round-robin - which might not be possible.
- BenPatt511Aspirant
Thanks for the quick response,
So in essence I'll be unable to get the same 200MBs write speed with the current set up, and capabilities of the NAS/Router?
Likely yes. I'm not familiar with the router, but generally routers and switches don't give you the option of round-robin.
