DougEa
Mar 03, 2019Aspirant
RN214 ReadyCloud doesn't discover during initial resync
Bought new RN214 and installed two new WD Red 4TB drives. Followed instructions to set it up, but ReadyCloud doesn't discover the RN214. RN214 says it is still resyncing. Is it normal for ReadyCloud ...
JohnCM_S
Mar 07, 2019NETGEAR Employee Retired
Hi DougEa,
Welcome to the Community!
ReadyCLOUD should be able to detect the NAS even if it is resyncing.
Is the ReadyCLOUD service enabled on the NAS? You may check this by accessing https://<ReadyNAS IP address>, where <ReadyNAS IP address> is the IP address of the NAS, then go to the Cloud tab. The ReadyCLOUD switch should be selected to ON. Please also check on that tab if Internet and Service has a green check on both.
- DougEaMar 08, 2019Aspirant
Thanks for your help. I first tred to log in using the IP (didn't work, can't remember details of why) and finally by using the RAIDar app left over from my old ReaydNAS duo ver 1. Through this I was able to connect to the RN214 and checked the Cloud option. This seemed to do the trick. I can now access the RN214 using Cloud, the IP or the RAIDar app. I'm still confused about how RAIDar can read the RN214, and whether it will be able to read the ReadyNAS Duo. I just ran the app (with the RN214 turned off) and it shows ver 4.3.8. Anyway, it definitely was not as smooth as the instructions led me to believe! Still have a lot to learn about this device, though.
- StephenBMar 08, 2019Guru - Experienced User
4.3.8 is needed if you want to set up the Duo in flexraid; 6.5 is better for the RN214 (and will work with the Duo).
https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Perhaps you can clarify what you are confused about?
RAIDar (and the NAS) use broadcast packets to find each other, and that technique works even if the NAS network configuration isn't matched to your home network. It will also find the Duo.
