ReadyNewbie
Feb 12, 2018Aspirant
RN214 Synchronization Offline
Hi guys,
I do have a quite silly question. When I am trying to 'sync' a folder from NAS via ReadyCLOUD app (sync with PC), I immediately get a red X and 'Synchronization Offline' displayed. The PC however, opens the folder location (which is empty). Same behavior on my MAC. So I guess it is a setting on ReadyNAS local IP homepage?
I am using RN 214, FW 6.9.2. Anyone had that issue before?
Thanks for suggestions,
ReadyNewbie
Hello :smileyhappy:
For now I suggest disabling the Anti-virus on the ReadyNAS. If the issue is not resolve, p
please attach a screenshot of the error message and the system logs.
Is your PC hardwired or wireless? Also, can you ping the ReadyNAS from your computer?
- ReadyNewbieAspirant
and I opened a support case in order to send logs. case #29725358
