Les214
Aug 14, 2024Aspirant
RN214 using USB Hub
I need more than 2 external drives to backup my NAS. I hooked up a USB hub and had two drives on it and they were both recognized. I added a third drive and all disappeared. The hub does not have ...
Aug 14, 2024Guru - Experienced User
Les214 wrote:
So am I correct in suggesting that I should use a USB Hub that has an AC power source?
I would certainly recommend that. The front USB port on the RN214 is USB 2.0. That limits both the speed and available power from that port. The USB 2.0 power spec is only 2.5 watts.
Netgear doesn't say how much power can be delivered from the two rear USB 3.0 ports. But the minimum is 4.5 watts, which might be enough for one drive, but not for two.
Sandshark
Aug 15, 2024Sensei
It's a bad idea to connect even one USB-powered drive to a USB hub without a separate power supply, be it on the ReadyNAS or elsewhere. The port is rated for one device -- in this case the hub.
