bastelspezi
Jan 27, 2018Aspirant
RN214 Volume gone after upgrade from 6.9.1 to 6.9.2
Hi Forum Members, I need your help. yesterday I updated 2 of my 3 RN214 NAS to the new firmware 6.9.2. and the one I had a RAID volume on it, cant build its volume no longer. I got 4 RED drives in...
mdgm-ntgr
Jan 31, 2018NETGEAR Employee Retired
bastelspezi your volume is encrypted. Is the USB key with the encryption key connected? The volume can't be mounted without this.
- bastelspeziJan 31, 2018Aspirant
yes of course. meanwhile I removed one of the harddrives just to see what would happen and it mounted the volume again. but obviously degraded. i backuped a few things off of it. and later installed a new harddrive in slot 4. then it resynced. it said it was successful, but the volume is messed up. I got now a lot of btrfs errors in the log files. it says the snapshots use 0GB of space but they are all there. but I cant delete them from the GUI. I think because the volume is apparently in read only. I also cant write onto it. I'm doing a scrub right now but i think thats making it all worse.
I have log files of every stage of the progress now.
I would really like to know how this all happend in the first place.
[Wed Jan 31 13:23:05 2018] BTRFS error (device dm-0): bad tree block start 17138530076113243935 17928296660992 [Wed Jan 31 13:23:05 2018] BTRFS error (device dm-0): bad tree block start 17138530076113243935 17928296660992 [Wed Jan 31 13:23:05 2018] BTRFS error (device dm-0): bad tree block start 17138530076113243935 17928296660992 [Wed Jan 31 13:23:18 2018] btree_readpage_end_io_hook: 14 callbacks suppressed [Wed Jan 31 13:23:18 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:23:18 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:23:51 2018] md: requested-resync of RAID array md127 [Wed Jan 31 13:23:51 2018] md: minimum _guaranteed_ speed: 30000 KB/sec/disk. [Wed Jan 31 13:23:51 2018] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for requested-resync. [Wed Jan 31 13:23:51 2018] md: using 128k window, over a total of 5855672832k. [Wed Jan 31 13:23:53 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:23:53 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:31 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:31 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:32 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:24:35 2018] nr_pdflush_threads exported in /proc is scheduled for removal [Wed Jan 31 13:30:19 2018] btree_readpage_end_io_hook: 14 callbacks suppressed [Wed Jan 31 13:30:19 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:30:19 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:30:19 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:30:19 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:30:19 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232 [Wed Jan 31 13:30:19 2018] BTRFS error (device dm-0): bad tree block start 5252102582698494194 17928298463232
- mdgm-ntgrJan 31, 2018NETGEAR Employee Retired
Do you have logs downloaded from closer to when the problem started?
It does look like there's some fs corruption.
Do you have a backup?
smart_history.log and disk_info.log show command timeouts on a few of your disks.
i've sent you the log file from right after the problem started (the one you have) I dont have anything from ealier since there was no problem.
i do have backup.
The timeouts showed up ever since I set up the system, didnt seem to affect anything. I posted about this issue 2years ago, I was referred to the compatability list. yikes. the timeouts seemed to not increase anymore once I had set the disk sleeptime to at least 45min.
thanks so much for your effort!
I realize the volume is pretty full.
I never did any scrubbing or defragmenting. I only ever did disk checks once a month
