ecybertom
Dec 28, 2018Aspirant
RN21400 HAVING VOLUMN ERROR AND GOING READ ONLY
I have two of this model, one purchased in 11-16-16 and one 9-5-18. Both running Firmware 6.9.4. Both were turned off for 2 months and restarted 12-4-18. Within a few hours of restarting, both (and an RN102) loaded Hotfix 1. Within 2 days of this hotfix addition, the older unit had a volume error and went 'read only'. I rebuilt the system and so far, seems to be working. This morning I found the new one went into error / read only mode. I've not had this problem berfore; the 102 system seems to be holding. If this is a recurring theme I'll buy another brand.
Are you seeing any disk or btrfs errors in the logs? Perhaps search system.log and kernel.log.
- ecybertomAspirant
ecybertom wrote:
Yes, btrfs errors. See attached
Well, that explains it.
Make a backup if you can - if not, you'll need data recovery to extract the data from the volume.
I'd start by testing the disks in a windows PC (seatools for seagate, lifeguard for western digital).
