Gz023247
Feb 07, 2016Aspirant
RN31200 ReadyNAS suddenly gone! #26436363
Hi everyone,
I will have had my RN31200 ReadyNAS (OS 6.2) 1 week tomorrow, and until this morning things seemed to be working great - especially for a newbie!!
However, I have run into a...
Feb 07, 2016Guru - Experienced User
Gz023247 wrote:
ar.
When booting up lights flash on the end of ethernet cable, indicating a connection, but then after 30-40 seconds go out. I was advised by a "chat" agent that the gigabit lan ports are not working and I should send the item back.
When the lights go out, can you ping the NAS? (on windows, run CMD and then type ping nasipaddress (using the real IP address of course).
Gz023247 wrote:
Problem is, it came from Amazon and I have been spending painful hours transferring data from a WD 3tb cloud hard drive to the NAS unit and don't want to restart the whole process again if I can avoid it.
You can migrate the disks you have directly to the new unit.
