Gz023247
Feb 07, 2016Aspirant
RN31200 ReadyNAS suddenly gone! #26436363
Hi everyone,
I will have had my RN31200 ReadyNAS (OS 6.2) 1 week tomorrow, and until this morning things seemed to be working great - especially for a newbie!!
However, I have run into a...
mdgm-ntgr
Feb 07, 2016NETGEAR Employee Retired
If it won't boot into a low-level diagnostic mode even with no disks installed and the USB disk disconnected that would suggest a faulty chassis. I understand that support has already walked you through that.
Gz023247
Feb 15, 2016Aspirant
Item has been returned back to Amazon now with full refund received as it would seem the unit was faulty. Thanks for everyone's help.
- mdgm-ntgrFeb 15, 2016NETGEAR Employee Retired
Support has reviewed your case and it seems you are probably running 6.4.1 not 6.2. This would suggest that you may have run into an issue that would have been resolved by USB Boot Recovery (note some USB keys are incompatible with USB Boot Recovery). That particular problem has been fixed in 6.4.2 (see Enhancement & Bug Fixes #17 in the Release Notes)
