JanuszP
Feb 02, 2021Aspirant
RN3138 raid degrader, will it rebulid
Hello. My volume is degraded, disk 2 of 4 is failed. I replaced disk number 2 and it seems the array is not rebuilding. I cant see disk 2 and 4 in volumes screen. Green leds in disks 2 and 4...
JanuszP
I've been looking at this screen for 6 hours and you finally wrote, thanks!
> Have you refreshed the display since you swapped the drive?
Yes, i logout and login again, few times.
Yes, my files are accesable, and have backup of them.
I think I can move files to another server, and recreate volume; willl you do that?
> Can you download the log zip file using the buitton on the Logs
I try, but logs are not generating, strange. And I see nothing in System- Settings- Services.
I wanted to setup SSH service, but I cant. And cant connect via putty on server (Im not sure SSH was turned on before)
> If the RAID didn't start re-sync, the question becomes why. Is the drive you added at least as big as it's mate?
No- disks are the same size and even PN ( I bought 5 disks, and one was waiting for today :-0 )
> Does the log even show that you added the drive? If not, could the new drive just be DoA?
No I do not see info in logs . What DoA mean?
Strange things is it that i cant restart server, even shut down. It tries to do that, but only one PING is lost during that operations. And Strange things is it that i cant restart server, even shut down. It tries to do that, but only one PING is lost during that operations. And UPTIME I have 98 days. WTF?
JanuszP
screen during logs downloading attached
