BuyingQnap
May 03, 2018Aspirant
RN314 Disk corruption
I've had this RN314 for a few yeras now but its been nothing but headaches, Right now Its holding my data hostage. It Keeps telling me error 0x80070570 The File or Data is corrupted - I am runni...
May 03, 2018Guru - Experienced User
BuyingQnap wrote:
The smart on the front end isnt displaying any errors. could there be errors that are not being displayed?
SMART is useful, but not everything - many drives fail without ever reporting a SMART error.
Do you have disk spindown enabled? That might slow down the test.
BuyingQnap wrote:
I don't really know Linux.
Then perhaps postpone that step for now.
If you purchased the NAS new between 1-June-2014 and 31-May-2016 then you have lifetime chat support at my.netgear.com. If that's the case, then it would be a good time to use it.
You could also download the log zip file (if you haven't already), and look in system.log and kernel.log for disk and btrfs errors.
BuyingQnap
Just tried to speak with them. i am out side of coverage, even thought i bought it in 2014... I think I literaly bought it 5 days before that time frame.
Label: '7c6efc30:Adonis' uuid: 9e1ad57c-9b40-45b0-9a0f-e1531c049988
Total devices 1 FS bytes used 9.66TiB
devid 1 size 21.82TiB used 11.11TiB path /dev/mapper/Adonis-0
=== filesystem /Adonis ===
Data, single: total=11.08TiB, used=9.66TiB
System, DUP: total=64.00MiB, used=1.47MiB
Metadata, DUP: total=14.00GiB, used=741.88MiB
GlobalReserve, single: total=148.12MiB, used=0.00B
=== subvolume /Adonis ===
ID 257 gen 192900 top level 5 path .purge
ID 258 gen 198509 top level 5 path ._share
ID 259 gen 198532 top level 5 path .apps
ID 260 gen 190318 top level 5 path home
ID 261 gen 50583 top level 5 path .vault
ID 262 gen 190318 top level 260 path home/admin
ID 263 gen 198551 top level 5 path W
ID 264 gen 198509 top level 263 path W/.snapshots
ID 265 gen 198536 top level 5 path .timemachine
ID 266 gen 190318 top level 260 path home/Evan
ID 23096 gen 191461 top level 5 path BackBlaze
=== qgroup /Adonis ===
=== btrfs dump-super
- StephenBMay 03, 2018Guru - Experienced User
You aren't eligible than, but is was worth a try.
- mdgm-ntgrMay 03, 2018NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
