Enimalist
Jan 30, 2020Aspirant
RN314 not boot.
Hello! My ReadyNAS RN314 unresponsive now fails to boot. Upon pressing Power button, Power button LED lights, fan spins on high, the disk drive #1 LED lights (2,3,4 do not), the LCD and ACT LED flash...
EHCanadian
Jan 31, 2020Star
The 314 has a hdmi port. Did you connect a monitor to it to see if anything shows up on the screen?
Enimalist
Jan 31, 2020Aspirant
Hello! Yeah, that 's the first thing I did. As a result, the inscription on the monitor: "no signal." The instruction states that the port is not used, page of the instruction.
- EHCanadianJan 31, 2020StarI had the 314, HDMI port worked.
Mine suffered the same fait as yours about a month ago. Got it RMA. They sent me the 424 cause the 314 was discontinued.
Basically your at a no post.
Power block led us green, sounds and looks like it is booting then nothing. Ether the internal flash is toast or a design defect as mine did the exact same as yours. Rebooted and never came back to post. Your data is fine tho. See if u can start the RMA process. Mine took about a week and a few days to have new unit.
