marsmars
Jun 25, 2024Aspirant
rn314 updated firmware to regain admin password, lost volumes
I have rn 314 6.10.10 firmware 4 hdds 4 tb each. statud shows healthy It was running happily, but recently because of repeated power failure for some reason (could be related to recent sola...
Jun 25, 2024Guru - Experienced User
marsmars wrote:
so after searching for solution i found out that i can reinstall firmware to reset password and done that.
Now I can access it. but it shows no volumes exist.
Likely also related to the power failures.
The message is a bit deceptive - don't remove any volumes.
Download the full log zip from the logs page. If you can't figure out what it means (likely will be the case), you can send them to me and I'll take a look. To do that you
- upload the full zip to cloud storage (dropbox, google drive, etc)
- send me a PM (private message) using the envelope icon in the upper right of the forum page
- include a link to the logs in the PM. Make sure the permissions allow anyone with the link to download them.
Best to get a UPS for the NAS. That will allow it to continue running during short power failures. More importantly, the NAS will be able to shut down cleanly when the UPS battery drains.
marsmars
Thanks for the replay.
I just sent you the link to the logs file
