Wenzu1981
Jun 02, 2022Aspirant
RN31400 – ReadyNAS 300 Series - Volume Data RAID Level 5 Innactive
Hi I have a Netgear Ready NAS 314. I recently have experienced an issue with my Ready NAS. Firstly I was not getting an IP address and had to do an OS Reboot to try and re-establish a connect...
Wenzu1981
Thanks
I have downloaded the logs, however I don't know what to do with them.
Prior to losing my IP address I tried to send a file accross to the NAS, and it stated it was write protected. I rebooted the unit and then the issues became apparent. It looks like the issues may have been there fore the software upgrade.
I am also happy to put in a support contract, however everywhere I go it states that I am out of warranty and am not sure where to go to obtain a support contract. Can you please send a link?
Wenzu1981
Would remounting the volume result in data loss? If not what is the process of doing this?
Would prefer to obtain paid support contract, and it would be great if you could advise how to do this. If 1 Hard Drive has failed I could easily replace, but my preference would be to retrieve the data. which would be about 8TB in data. Mainly video files.
- StephenBJun 02, 2022Guru - Experienced User
Whatever caused the mounting problem could also have created some data loss. There's no way to tell at this point.
There are multiple causes, and also more than one possibility for remounting. Which is why I usually point people to support.
Understood.
FWIW, RAID isn't enough to keep your data safe. A backup plan is the best way to do that. So perhaps put that in place after you (hopefully) get the data back.
The NAS made the volume read-only in order to protect the data. Rebooting at that point was (unfortunately) a bad idea. If would have been better to back up the data before doing that.
Mods, and possibly support will want to review them. Don't post the full zip publicly, as there is some privacy leakage.
They are confusing, but you can look in system.log, kernel.log, and systemd-journal.log for btrfs and disk errors.
If you log into my.netgear.com, and look at your registered product list then you should see a "support options" control on the right (right under "Product Info"). One of those options should be "purchase a support contract"
But wait for the mods ( Marc_V , JeraldM ) to chime in. I just tried clicking on that link on my RN526X, and it isn't actually giving me the option to purchase.
- Wenzu1981Jun 02, 2022Aspirant
All support options being Phone, Chat and email have expired. Also hardware, accessory and power supply warranties have expired as well.
There is no option to purchase a support contract, however there is an option to activate a support card, however in order to do this I require a support contract with an activation key.
As all warranties and support have expires as the product is more than 5 years old, does this mean Netgear will not provide support?
Please note that I have a case Number (46064517) and have uploaded the logs to Netgear, however they have been non-responsive.
I am unable to purchase a support contract. I think this is because my product is out of warranty and more than 5 years old.
